You’re good to go! Your system is now fully operational and you are able to now install new apps.
ok back to brave installation! Thank you thank you thank you!
My pleasure, truly! Now the script will work nicely.
By the way, @Paul - if you like, Jeff invited you to share your experience in this issue on Tuesday’s Telegram call if you’re up for it.
I am now on Brave on the HP! Wow, again quite the struggle but worth it! That little bit bad on the hard drive is very small at best, so it was worth the work! I have learned so much but so much of it to absorb!
Thanks again for all your help! So far this has been a great experience in learning.
And it has honestly been my pleasure to help out! There is always the struggle, but nothing ever worth doing is easy.
If you’re available on Tuesday, we’d love to have you on the call!
Absolutely! If the call is at 8pm eastern time, I can do it.
Yes, it is. Your trial will be a great inspiration for everyone else out there!
Thank you so much!
I am about to get bold and try to load wine…oh boy, I hope this one works! LOOOOOL
It will work. But, if you want all Windows apps to work, you might want to have a tutorial I have for it here
Oooff … I think I will wait until I have a little more time to get into this one. I’ll pick something a little bit less aggressive for the moment. I will read this thread and do this when i have a little more time to do it. Thanks!
Take your time! You went through quite the ordeal today.
Well the next day after getting all what worked on working, this error happened from power up. It sat for a few minutes before more info came out the I left it for 4+ hours and no further changes.
Hello again, Paul!
It would appear your drive is sending you a love letter! In short, I think you might want to replace it. There’s another file-system error up there.
hard drive is replaced! SSD is so much better!
It’s incredibly better! And you won’t be facing the issues you had prior.
Enjoy!
was there still a call tonight?
I was wondering the same thing. I just asked Jeff and I’ll let you know for sure.
The call is for tomorrow, Wednesday, same time.
