Things are still very flaky. Often doesn’t find WiFi and system freezes if I try to close Unity (which won’t close). Sometimes you have to restart Unity for settings etc. to be changed properly (eg. importing a package), so xkill or system restart doesn’t do that.
Also Unity rendering is poor - any dragging leaves a ‘trail’.
Encouraging start, but not feeling very encouraged now. This whole process is certainly draining me.
And here comes the big question. Have you installed the Nvidia drivers for your RTX? The performance increase is legendary - with zero artifacts. I know because I’m running with one on my system.
The big answer is no. Didn’t do that specifically for Ubuntu. How do I do that?
However, still having issues with Unity not closing (apparently this is not uncommon) and I can’t resolve Java issues at the moment, so still can’t build for Android. Been searching for answers, but no luck so far.
No wonder you’ve been having graphic issues with Unity!
Go to your apps and look for “Software and Updates.” Then go to the “Additional Drivers” tab and it will do a search. After a little while, it will pop up the different versions of the Nvidia Driver. Select the 470 one and once done, reboot.
Per the Java part, if it says it can’t find it, then it could be an option of setting the $PATH for its binary so that Unity is able to find it. Unfortunately, I haven’t used Unity 3D at all, so don’t take my word for it!
I completely forgot you switched! My brain is all over the place! LOL
You can open up pamac (software manager) of Manjaro, go to settings and activate the Arch User Repository (AUR). Then search for Nvidia in it. That should provide a few options.
However, before you install, I’d recommend uninstalling what you previously installed.
I did a clean install of Manjaro. The ‘run pamac’ option does nothing at all. I found an option to enable AUR, found some random nvidia options, but they just sit forever checking conflicts, etc.
I think I’ve reached the end of the line with this.
Thanks again for your patience and assistance. Muchly appreciated!
The reason it’s seemingly sitting forever is because it’s compiling a lot of stuff in the background. However, there’s another way to install the Nvidia drivers. I have it as a tutorial here - in case you decide to stick around.
I really appreciate your willingness to help others pick all this up. Can obviously be a minefield!! So important we build our own alternatives to the Big Tech oligarchs. It’s happening! Social media, indie journalists, failing MSM, blockchain, truth being exposed (election fraud, fake pandemic/vax mandates, US borders) etc. etc. Exciting, though difficult, times! Once one domino falls…
Linux is definitely our future. Especially if the community can get it going on mobile devices, with an easy migration path for app/game developers. Unity will be a big part of that - very indie dev focused.
If I can’t get this going with one last try, I’ll def keep my eye on Unity etc. in the Linux sphere. They seem to be getting there.
The tutorial is here and it should work exactly the same with Manjaro. I know because I did it on Arch (the “father” of Manjaro).
Keep in mind: The command to install DKMS on Manjaro is:
sudo pacman -S dkms
As Manjaro uses pacmac instead of apt.
And yes, helping people and having them smile at the end of the day - well… it makes my day. Honestly. They say that “If you want to see a good change in the world, then become that change.” - In short, it’s the “Lead by example” approach.
Driver manager is for the Ubuntu/Mint distros. You don’t have to worry about that. As long as you haven’t attempted to install Nvidia on your fresh Manjaro Installation, you should be fine.
