Does your printer have a usb connector and a usb cable? If it does then I would try setting it up with the USB connected. If that works then you could add the wireless later. I have had to do that with a couple of HP printer in the past.
If you do not have a usb cable or connection then I wouldn’t buy one just yet. There has to be a simple thing we are missing.
Your terminal says your computer is a Lenovo, have you tried tech support with Lenovo?
I’ll keep looking for answers and if I find anything I will post back here.
In the mean time if anyone has any experience with Linux Mint (Ubuntu) and setting up printers please jump in here and give hermis3 a hand.
After plugging it in did you set up a new printer with the with the Printer tool on your desktop menu. Delete any old ones and then add a new one looking for the usb printer.
If it still doesn’t work then I have found another thing that might help.
I have found something that may work if you still have time to work on it. If so then delete all of the printer you have set up with the add printer utility and we will go back to the command line. Let me know if you want to and when you are ready. We could wait until tomorrow if your want to take a break from this today.
I have time. first, when you say “delete” the printers maybe I am doing it wrong. I just pull up the printer list and hit delete. is that enough, or is there a remove thing in the command box I should be doing?
here is the last little bit…
linux-modules-extra-5.4.0-113-generic linux-modules-extra-5.4.0-117-generic
linux-modules-extra-5.4.0-120-generic linux-modules-extra-5.4.0-121-generic
linux-modules-extra-5.4.0-122-generic linux-modules-extra-5.4.0-124-generic
linux-modules-extra-5.4.0-125-generic linux-modules-extra-5.4.0-126-generic
linux-modules-extra-5.4.0-128-generic
Use ‘sudo apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
nancy@nancy-Lenovo-YOGA-730-13IKB:~$
nancy@nancy-Lenovo-YOGA-730-13IKB:~$ ls -al epson*
ls: cannot access ‘epson*’: No such file or directory
