I am new to LINUX and I am looking for my first Distro.
After a lot of searching, I am going to try Zorin OS 16 and Mint.
I have searched this website and did not find any mention of Zorin, any insight would be appreciated.
Thank you
Thank you
Hello @Ubdavis and welcome to the forums!
I have heard great things about Zorin 16, especially the Pro version. The reason you haven’t found anything yet is because the forums are barely a month old, so everything is building up as we go.
Therefore, we have decided to essentially start with the distro that most people will feel comfortable in. That would be Linux Mint and Ubuntu - though there are a few of us more advanced that will go for a different one.
Know that Zorin is based on Ubuntu, so a lot of the troubleshooting done here applies on Zorin as well.
Thanks I will start with Mint and watch for Zorin
Well, I installed Mint and Zorin Core on bootable usb drives and ran them on my Samsung laptop and my Lenovo desktop. After trying each one for a few days, I have decided on Zorin Pro. The installation on the laptop went fine but the desktop was a little trickier due to extra storage drives.
Thanks
Ubdavis
Hi Ubdavis,
My two cents, start with Ubuntu. I think it’s the least “painful” transition from Windows (admittedly, I haven’t had a Windows box since 2004). Ubuntu is the most popular, so a lot more users to guide you through a new system. Start with the easiest to install, with the largest community, then go from there.
It always is on systems where there are many drives! I used to scratch my head back in the day when I had identical drives in the system. I’d have to disconnect them all but the one I wanted to install the OS into.
After running Ubuntu LTS for a couple weeks, decided to overwrite it with Zorin 16 Core yesterday. Thinking I’m liking Zorin’s Desktop better.
Zorin is a great distro, indeed! I purchased their Pro version and it’s truly great!
I’m now on my 3rd Distro. Zorin stalled on my first, so I installed Ubuntu LTS instead. After perhaps a couple weeks, I wiped it and installed Zorin 16 Core. Now I’ve installed Mint Cinnamon. I’m thinking I like Zorin better, but I’ll use Mint for awhile longer. Perhaps Arch Manjaro or Pop OS next.
POP!_OS is basically like Ubuntu with a few differences on the dock. If you want to see a bit of a drastic difference, I’d recommend trying Manjaro.
Eventually, I settled on Zorin Pro 16, as since my time has become quite limited, I need something that actually works without too much hassle.
I actually installed both Manjaro KDE Plasma and PopOS, but have already resorted back to Zorin 16 Core. Thinking I’ll rest here. It works nicely.
So Zorin Pro 16 is your daily driver, and Gentoo is your project.
Is this dual-boot on the same device? Or multiple devices/computers?
Currently a Dual-Boot. Or a triple, if you count Windows 11 I almost never boot into. I also run Zorin Pro on two more laptops and I noticed that my Surface Laptop 3 doesn’t overheat with it at all. Perhaps because it has the CPU governor and GPU settings set nicely on it.
@vasileios Hey
, I have been looking at Zorin 16 and liking what I see. This is a 2014 MacB Air I7 with this graphics card in it Intel® HD Graphics 5000 (HSW GT3) Should I want to try it, would I install the regular version or Nvidia version. Thank you
I installed the Regular version of Zorin 16 Core on my Intel Integrated Graphics (HD Graphics 3000) laptop. Works great.
Thanks for the feedback on the Pro version. It looks very polished. And does have some very nice features.
I have searched for what it calls the “Professional-grade creative suite of apps” and the “Advanced productivity software” that come with it, but have not found a list. I assume those are all open source.
Do you know of a full list. No need to compile one. Just curious.
Thanks.
For an Intel HD card, you just need the regular version.
I haven’t checked it fully, to be honest. A few apps that I did (all OpenSource) are Gimp, Krita, Blender, KDEnlive, OpenCAD, Ardour (audio), OBS, and others. Though they’re pretty stable and working nicely.
thank you @MarkMcCoskey and @vasileios
Thank you Vasileios.
