I am using a WiFi adapter (AWUS036ACS) to connect to the internet but am receiving a “device not ready”. I want to use this as a replacement for the internal Broadcom WiFi due to issues with outlined in this post. The Broadcom WiFi connect typically needs a system reboot in order to work. My goal is to leverage the AWUS036ACS as the primary device for WiFi, but the adapter doesn’t register.
I followed this tutorial, it worked initially, however, it no longer registers.
Bus 001 Device 002: ID 0bda:0811 Realtek Semiconductor Corp. Realtek 8812AU/8821AU 802.11ac WLAN Adapter [USB Wireless Dual-Band Adapter 2.4/5Ghz]
Operating System: Kali GNU/Linux Rolling
Kernel: Linux 5.15.0-kali2-amd64
Architecture: x86-64
Hardware Vendor: Apple Inc.
Hardware Model: MacBookPro12,1
I was able to install compiling by source. However, the WiFi Network Realtek 8812AU/8821AU still says “device not ready”. I’ve disconnected from the WiFi Network Broadcom and Subsidiaries BCM43602 but it seems that is the only network that is available.
My goal is to use the Realtek 8812AU/8821AU WiFi adapter to replace the native Broadcom since it has much better coverage.
Do I need to somehow activate the Realtek device via the CLI?
Hey @labeef and thank you for your kind words!
First, let’s disconnect your external WiFi. Then, activate your Broadcom and execute the following command (you’ll need Internet for that):
sudo apt install tlp
Once it installs, type in:
wifi toggle
Then connect your Realtek and see if it now works. If not, try:
Running the following commands seems moves the Realtek from “device not ready” to “disconnected” which seems to be what I want. However, it does seem like I’ll need to do this every time I reboot.
My WiFi network only appears under the “Connect to hidden WiFi network” option which displays the following error…
Connection is not available on wlan0 because profile is not compatible with device (mismatching interface name)
In short, the Broadcom Network displays my network NETWORK_NAME and NETWORK_NAME 1. I’m not sure why two versions show up which could also be another issue. It was working at one point but this duplicate network name seems to be causing the issue.
I was able to remove my main network through network config options. However, it seems like my wlan0 network access point is associated with the Broadcom MAC address.
wlan0 IEEE 802.11 ESSID:"NETWORKNAME"
Mode:Managed Frequency:5.785 GHz Access Point: BROADCOM:MAC:ADDR
Bit Rate=24 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=59/70 Signal level=-51 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
wlan1 IEEE 802.11bgn ESSID:"STRANGE_UNICODE" Nickname:"<WIFI@REALTEK>"
Mode:Managed Frequency:2.437 GHz Access Point: REALTEK:MAC:ADDR
Bit Rate:72.2 Mb/s Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality=100/100 Signal level=-27 dBm Noise level=0 dBm
Is there a way to associate the wlan0 with my Realtek WiFi adapter?
Hey @labeef!
Changing the device name can be a tricky one, especially when there are two of them. However, you can try to cycle them around (by temporarily renaming wlan0 to wlan2 and then shifting it to “1” when you make wlan1 into wlan0).
One pathway I found for it is in the following article, but I don’t have a system with two WiFi devices to check it out.
