Did you make sure you switched in to the Downloads/ dir before running:
sudo dd if=linuxmint-21-cinnamon-64bit.iso of=/dev/sdb bs=1M status=progress
Otherwise you have to provide the full path to the ISO
That’s the part that’s confusing to me. How to I do that?
when you open a terminal
cd Downloads
then you run the command.
So I did cd downloads and got:
bash cd: downloads: No such file or directory
I strung them together and got:
cd downloads sudo dd if=linuxmint-21-cinnamon-64bit.iso of=/dev/sdb bs=1M status=progress
bash: cd: too many arguments
I did sudo cd downloads and got:
sudo: cd: command not found
Downloads, case sensitive.
cd Downloads
Thank you. Here’s what I got:
2443182080 bytes (2.4 GB, 2.3 GiB) copied, 349 s, 7.0 MB/s
2335+1 records in
2335+1 records out
2449342464 bytes (2.4 GB, 2.3 GiB) copied, 515.731 s, 4.7 MB/s
Done. Now place it in your Mac and use it’s boot from USB procedures of which i know nothing of other then you may be presented with 3 options, 2 of which will should be UEFI .
Research it for your particular model.
I have Linux Mint on the Mac! Thank you so much for your help! You helped me while allowing me learn a few things. I have a LOT more to learn.
Congratulations!
That’s what we’re here for.
@MrDeplorableUSA, just wanted to say how much I appreciate the way you help Tee out!
Would you explain what the issue is with the USB not working? Or just what was the difficulty Tee experienced?
@Tee,
I love that you did not give up! I can see you getting good at Linux quickly.
So happy to see your successful installation!
On the Mac it was likely not recognizing the working USB since it was not first formatted to a mac format so etcher could change it to fat32 and perform the job.
I can not vouch for that since I don’t have a Mac but that seems to be the consensus from the setting up USBs on the Mac side.
Thanks! I was close to throwing in the towel, only because getting time to focus on it was hard and sometimes I lost track of where I was with the gaps in free time. I’m really glad for wonderful help that gave me a solution!
I’ve had fun setting things up the way I want, found solutions on my own to a few hiccups.
Tomorrow, schedule allowing, I’m getting on to switching the last machine over to Linux.
In one of my reformatting attempts, I did format to a Mac without success. I wonder if it helped that I switched USBs and used the solution you gave me. Either way,
I’m so glad it’s done! Have had fun setting things up and solving a few hiccups on my own. Still have a lot to learn.
So, not having a Mac OS to play with we went another route.
Though from this Gab post it may make some sense of why it wasn’t working for you on Mac OS either:
That makes sense. I’m so glad to be getting away from MacOS and from Microsoft.
Well…third machine comes up with a black screen at restart that never changes. I’m not done trying to figure it out…
Reinstalling Mac Os and starting from scratch. I’m surprised I can do this since I had the option to get rid of anything but Linux.
That certainly is interesting. My Mac is so old, I could not use any of the popular installer making apps. Luckily I was able to do that from my Chromebook then used ChromdOS recovery extension to make the installation USB to replace Chrome with Linux (Kind of funny now I think about it ) before converting my Mac.
