I have Ubuntu installed on an external hard drive that I can boot to. It was Ubuntu 20.04 LTS, and I was just trying to upgrade to 22.04 LTS. The ext4 partition was already mostly taken up, and the upgrade added files, so I feel like I need to extend that partition. I got errors on the upgrade, and it looks like it failed and is trying to recover. I suspect it’s the partition size(s). When I initially did the 20.04 LTS install, I decided to try doing manual partitions (to get the experience), so that’s what caused my problem. I did follow a template for recommended partition sizes, and the other ones are probably okay, but I didn’t leave myself much room for expansion on the ext4 partition. It’s a 1GB hard drive, and that Linux install is all I have on there, so I have lots of unallocated space.
It looks like I can’t do this with GParted (partition app) while running Linux. It looks like I’d have to launch GParted from CD/USB (flash drive) and “unmount” the partition before expanding it.
Does this sound right? I wanted to ask for advice on how to go about this before trying that method. Thanks!
(It looks like I might need to expand the Root partition too, as I got messages about that during the upgrade attempt)
