I don’t know if this is the proper place to post this question. The beginner’s sub has this as one of its 4 specs: “* Discussions regarding planning and implementation regarding switching from Windows and macOS to Linux.” Choosing a distro is certainly “planning”, but then I figured here’s a sub thats called “Linux Distributions”, so I should post here. But then I see its “a good place for questions and answers that are specific to certain distributions”. Finally I just figured I’d post the question here, and if its in the wrong spot let me know. And with all of that said, you see I have somewhat of an OCD over details.
I’ve been trying to pick a distro. Here’s my system list:
iBook G4/something (this is the one I installed Linux Mint on and it was so incredibly slow I couldn’t do anything with it)
MacBook 2009 (works beautifully but its not supported for security updates anymore, so I use it for ripping and burning cds)
iMac late 2012 (I had Elementary running on this prior to HD replacement)
iMac 2017 (my current workhorse)
I think the MacBook or 2012 iMac would be ideal for Linux. Ultimately I’m going to get a modern iMac and retire the 2017, so that can go into Linux land as well. Whatever machine I use, whatever distro, it needs to communicate with my Apple Airport Extreme, 6th gen, btw.
I have the same question every newb has: “which distro?”, and the answers either point to a guide article/video that allegedly shows the differences, or else they say “just try a few and see which one you like”.
My ish with the first answer is that those articles and guides and videos really don’t show the differences. They tell you a little about each one and why you might like it, but they don’t get into any facts. Why would one distro really be more secure than another? It can’t just be because it has fewer open ports on install, because you could just shut the ports on any other install, right? So it has to be something more technical. It can’t be look/feel, because thats just the desktop/window manager, and those can all be installed across different distros, right? So there has to be something more. So none of the guides explain real differences between distros. If there’s one out there that actually does that, I’d enjoy seeing it.
Which leads to the inevitable second answer - “just try a few and see which you like”. Well, I have no idea what I’m supposed to be doing with Linux that would enable me to tell distros apart. I suppose it would be like Mac vs Windows: it sucks to install or uninstall software on Windows, to add new hardware, or a million other things, compared to the Mac. Is that what I’m supposed to be looking for here?
Finally, I should say what it is that I hope to do with the Linux machine. Browse, email, post on dozens of forums, read/study, those are my main things. I also have a lot of music and movies stored on my router drive, so maybe it would be cool to have a distro serving that? I have attempted programming at various times but I’ve never been any good at it. Maybe that’ll change if I have Linux running, so being able to run some IDEs would be a good thing, I guess.
I’m sure there’ll be more things that pop in my head if I’m lucky enough to get a convo started about this. Any help would be appreciated.
You’re almost there! I’ve played around with distros myself for years, but I seem to be sticking with Zorin now. Perhaps have a second system to just play around with distros to get creative ideas (or keep my brain under constant challenges)!
