Hey @Td!
I’ll need to get into the antiX OS so that I can get to understand its structure - as I don’t have much experience with non-systemd versions - aside from Gentoo.
Per the Kernel, you can get specific versions via the mainline app:
sudo add-apt-repository ppa:cappelikan/ppa
sudo apt update
sudo apt install mainline
Per your other questions (keep in min:
- The command to move files is mv followed by the source location/file and then the destination_location/file. If you’re moving system files, then you’ll need to place the sudo command before the mv.
- The command to get to your desktop is
cd ~/Desktop(keep in mind, root user does not have a Desktop, so you’ll need to replace it withcd /home/Tara/Desktop. - The command to uncompress a tar.gz file is
tar –xvzf name_of_file
Per your OS installation, as I mentioned above, I’m not familiarized with the range of drivers and firmware it supports (the linux-firmware-nonfree used to exist for antiX). Since you have a modem/wifi that is a bit rare, I’d recommend you give another distro a shot and see if it’s recognized. Alternatively, you can attach a USB WiFi to your laptop.
