Yes, you can copy paste everything, but one line at a time. Alternatively, you can attach them in a single line, but separate each command with the && symbols.
Wow! You have quite the upgrade there!
First, I see the bar progress below, which means that somehow an installation process is still undergoing in the background. Is the bar progress advancing?
Then I would recommend to close that terminal and start a new one. This one is overloaded and frozen. Your issue mainly began due to version miss-matches. So, we’ll need to go to try a full system upgrade first.
Open up a new terminal, after you closed the previous one and type in:
Ok, got through it all successfully. Rebooted. My heart fell when there was no network symbol in the bottom. No connection. SMH. No locks, tho. The only connection that shows is the wired one I am hard-using. I am typing on my other laptop.
I thought you had given up on me. That did not work, altho it did say the install was successful. I’m wondering if I can’t add a profile and force it to pick up the router?
Hey @Stacey!
No, I don’t give up! I’m a bit too hard-headed!
However, I do find it interesting that the two main driver setups didn’t work. When you open up the Network Settings, does it still only present the Wired option?
Out of curiosity, is Secure Boot enabled in your BIOS? There are quite a few cases where it hinders additional modules - and disables WiFi and Bluetooth (I helped a couple of people here in the forums who had that exact issue). Please check it out.
If it’s disabled, then we’ll go on ahead and re-install the overall driver - in case it was disabled to begin with (we now have all the firmware files installed).
