We are texting right now … did you disable VT-d in bios??? Is there an added interface under Bios > Security > I/O interface security > new card interface and, is it set to lock?
I just told the bios version you have and was asked - was that motherboard replaced with a newer one or was the bios updated?
I get the setup menu for Mint, I select the first item to start the install and it goes to black. Other times I tried other options and it always turn to black screen. So its reading the USB but something is blocking its operations
AHCI isnt a factor - so… ok I just take that like it is
It sounds likes like a permissions issues… Im looking in reddit
on this and the one person who said - its easy! … Installed a new
hd and went on. Surely its not something they do on their drive
installs?
Ok… this wasnt a successful chat: “Wade, Linux isnt officially supported by the company.”
HAH I wont post I replied with so… I was kinda left hanging.
Im looking in a forums right now and … dang … Asus is just difficult on all their models. The two Ive worked on - I was sooo lucky compared to many of these people.
Im going to get another text tomorrow after they get to work and see if they can give me some more direct help. Ill post back then.
@Paul - which app did you use to flash the USB? Sometimes Balena may botch it and Rufus ISO recording may not work. In that scenario, I discovered that flashing in Rufus DD mode helps.
Also, I had the same issue with the black screens. It turned out the USB stick was new, but only worth for the trashcan! Everything worked the moment I used another flash drive!
This is the flashdrive I have used on all my computers so far. It was a Rufus ISO. What is a Rufus DD?? This san disk I tested with another computer in the beginning and it worked on that HP. From what Wadesmart was saying this seems to be a ASUS thing.
I did start out thinking the USB was a fault. The computer doesn’t even read on the other USB port. This one might have some issues also. I just don’t know!
Ah, yes! If you tap the Escape key more than once (or hold it), then it jumps you into Grub. It happens to my HP too. Are you booting from your USB?
If yes, then you may have bypassed the boot issues and you’re going in.
Also DD is a recording option Rufus offers when you hit the Flash button at the end (when you’ve selected the ISO and the USB thumb drive).
Vasileios, Im thinking he could cd into hd2 (assuming that is the thumbdrive)(maybe on this system a bad assumption) or one could reformat the whole hd from to allow the install a better chance at success.
Since there are quite a few drives, I believe the ones you’re looking for are:
(hd1,msdos1) which is your boot, and
(hd1,msdos2) which is your root.
Now, type in and cross your fingers!
root=(hd1,msdos1)
Here, press Enter and hope no error message appears. If there is, use msdos2 above.
Now comes for the tricky part.
linux /vmlinuz
Don’t press Enter yet. Instead, press the TAB key. If there is a Kernel image in there, it will autocomplete the version. If there isn’t one, it will do nothing. Then you’ll have to go to the first command (root=…) and replace the msdos1 with msdos2.
However, if the filename completes, press space and type (same line):
root=/dev/sda2
Press Enter here too.
Now, for the next command, you’ll need to utilize the TAB key again:
initrd /initrd
Now hit the Tab so that it hopefully completes it with the .img extension at the end. If that happens, you’re almost there. Hit Enter and type in:
So as it is initially starting, I get an error flashing on the screen that says: error: file ‘/boot/ ‘ not found
This is when starting the computer, not the grub
