I am a new Linux user (less than 1 year) and I am enjoying the experience this time around. But, I am having an issue that I don’t know how to fix or troubleshoot to determine the cause.
I have a Dell XPS 2-in-1 that came with Windows pre-installed. I tried a number of distros before I settled on Zorin based on the look, ease of use, and the installed apps. Periodically, I have issues with the system freezing. There isn’t a consistent thing that causes the freeze. I could be using LibreOffice and scroll too fast with wheel on the mouse and the system would freeze. Other times I could change a tab in the Brave browser and the system could freeze. Sometimes the browser is an issue where I just have to wait for the dialog box to pop up to shutdown the browser and then everything is okay.
The type of freeze I am referring to is where the mouse completely stops moving and my only option is to either hold the power button to turn the system off or use the Linux RESUIB key combinations.
I am not sure if there is a hardware issue that is causing problems or if some of the installed software/drivers are causing the problem. i would prefer not to leave Zorin, but, if there is a compatibility issue I may not have a choice.
Any help or guidance would be greatly appreciated.
PS: I saw in another thread in the forum of a way to take a snapshot of the system details using inxi…
System:
Kernel: 5.13.0-48-generic x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13.0-48-generic
root=UUID=ab7002cd-6410-405e-8628-1d3a3dcbe15e ro quiet splash
vt.handoff=7
Desktop: Gnome 3.38.4 wm: gnome-shell dm: GDM3 3.38.2.1
Distro: Zorin OS 16.1 base: Ubuntu 20.04 LTS Focal
Machine:
Type: Convertible System: Dell product: XPS 13 9310 2-in-1 v: N/A
serial: Chassis: type: 31 serial:
Mobo: Dell model: 0062CR v: A00 serial: UEFI: Dell v: 2.7.0
date: 12/11/2021
Battery:
ID-1: BAT0 charge: 41.3 Wh condition: 41.8/50.0 Wh (84%) volts: 8.5/7.6
model: BYD DELL DD9VF11 type: Li-poly serial: status: Charging
CPU:
Topology: Quad Core model: 11th Gen Intel Core i7-1165G7 bits: 64
type: MT MCP arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1
microcode: 9A L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 44851
Speed: 1029 MHz min/max: 400/4700 MHz Core speeds (MHz): 1: 732 2: 1281
3: 1211 4: 896 5: 938 6: 1106 7: 1203 8: 1095
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel vendor: Dell driver: i915 v: kernel bus ID: 0000:00:02.0
chip ID: 8086:9a49
Display: x11 server: X.Org 1.20.13 driver: i915 compositor: gnome-shell
resolution: 3840x2400~60Hz, 1920x1080~60Hz
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.6
direct render: Yes
Audio:
Device-1: Intel vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 0000:00:1f.3 chip ID: 8086:a0c8
Device-2: Altec Lansing type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 3-8.4.3.2:9 chip ID: 04d2:9801
Device-3: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus ID: 3-8.4.3.3:11 chip ID: 046d:085c
serial:
Sound Server: ALSA v: k5.13.0-48-generic
Network:
Device-1: Intel vendor: Bigfoot Networks driver: iwlwifi v: kernel
port: 3000 bus ID: 0000:00:14.3 chip ID: 8086:a0f0
IF: wlp0s20f3 state: down mac:
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 2-1.4.3.4:8 chip ID: 0bda:8153 serial:
IF: enx00e04c056488 state: down mac:
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 2-1.4.5:6 chip ID: 0bda:8153 serial:
IF: enx98fdb49aa495 state: up speed: 100 Mbps duplex: full mac:
IF-ID-1: virbr0 state: down mac:
IF-ID-2: virbr0-nic state: down mac:
Drives:
Local Storage: total: 14.13 TiB used: 12.02 TiB (85.1%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/mmcblk0 model: GFAQK size: 476.91 GiB block size:
physical: 512 B logical: 512 B serial: scheme: MBR
ID-2: /dev/nvme0n1 model: KBG40ZPZ1T02 NVMe KIOXIA 1024GB size: 953.87 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: rev: 10400105 scheme: GPT
ID-3: /dev/sdb type: USB vendor: Western Digital model: WD My Book 25ED
size: 12.73 TiB block size: physical: 4096 B logical: 512 B
serial: rev: 1031 scheme: GPT
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller
driver: vmd v: 0.6 port: 3000 bus ID: 0000:00:0e.0 chip ID: 8086.9a0b
rev: N/A
Partition:
ID-1: / raw size: 953.37 GiB size: 937.40 GiB (98.33%)
used: 743.70 GiB (79.3%) fs: ext4 dev: /dev/nvme0n1p2
Sensors:
System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 398 Uptime: 2h 35m Memory: 31.07 GiB used: 5.89 GiB (19.0%)
Init: systemd v: 245 runlevel: 5 Compilers: gcc: 9.4.0 alt: 9 Shell: bash
v: 5.0.17 running in: gnome-terminal inxi: 3.0.38
