workshop 3 on Oct 9th - install vpn on vps.
I am at the addpeer . sh step, but it will not produce a public key (I think that is the problem)
Hello @Mitch and welcome to the forums!
WireGuard is a fast VPN solution, but it still has some issues as it’s fairly new. If your issue is the SSH, there are a couple of lessons on the LMS that covers it in detail. We also have an OpenVPN course that I believe you will find that flows much easier for you.
Thank you! I appreciate your help. They told me you have a great video on how to set it up in the course. I’ll check it out.
Hey @vasileios
I need lesson 012 without the music and tonality in the background, it upsets my autism (I cant watch it). Is it possible to get a copy without? Thank you
Hey @CC!
I have heard about the specific video once before. I will do my best to change it, though it may take a little bit. The reason is that Adobe messed up their upgrades, which - in turn - messed up the project foundation I had for those videos. However, I think I may have set this up on a different platform.
I will check it out and let you know.
I tried copying it, to get it into a cc player (closed caption), no can do…
I need it.
Thank you very much
Done. You will find the video without the soundtrack as 2.b. in the course.
Wow! Thank you, going there right now.
You’re welcome! I’m doing alternate versions on 3 videos. 2 of them are already up. The last one needs some time to render.
It’s perfect! You’re the best!
I’m glad! Now you can enjoy!
Now I can really generate ssh keys…
lol
@vasileios you know, windowZZz ten, downloaded a ton of stuff and stopped my security working. Which freaked me out, I’ve got to have control of this machine. I uninstalled what I could, it won’t allow me to uninstall the browser edge… crazy.
I wanted to download the Linux package immediately but I need to shh the VPS and make a VPN.
You will be the first to know when I have!
Of course! Edge is one of the Apps WindowZzz 10 will never allow you to uninstall. Not directly at least.
Speaking of VPN, I have an extensive video for it (OpenVPN) on course 18. This is the last video I’m creating a no-music version for. However, it comes with an extensive instructions PDF, which you can use. If you can wait for a little bit more, I can have the new video up too. If you’re in a hurry, just grab the PDF from the top right corner of your LMS screen (under “Files”).
Hey @vasileios , do you only make one passphrase for a computer?
Yes. One passphrase that you can use for all the VPSs you connect to.
Edge wasn’t apart of my package, I had to install it. When I factory reset this computer (twice now) there is only internet explorer. They recommend you get edge ( We recommend you transition to Microsoft Edge to enjoy a faster, more secure and more modern browsing experience.) In add and remove the icon will not uninstall edge.
I want it bad but am patient as a tortoise. Rather do it correctly the first time an then never worrying about. One more week and I am free…!!!
