Or, try this.
#!/usr/bin/env python3
# may need to run "pip install vobject" first
import csv
import vobject
import argparse
def vcf_to_csv(vcf_file, csv_file):
try:
with open(vcf_file, 'r', encoding='utf-8') as vcf:
# Read all VCards
vCards = list(vobject.readComponents(vcf.read()))
print(f"Total vCards read: {len(vCards)}")
if not vCards:
print("No vCards found.")
return
with open(csv_file, 'w', newline='', encoding='utf-8') as csvfile:
csv_writer = csv.writer(csvfile)
# Empty lists to hold headers and content
headers = []
content_list = []
# Extract headers and content
for card in vCards:
# Temporary dictionary for the current card
card_dict = {}
for key, value in card.contents.items():
# Capture all keys and their values
if isinstance(value, list):
card_dict[key] = [str(v) for v in value] # Convert value(s) to string
else:
card_dict[key] = str(value)
# Only add keys to headers if they don't already exist
for key in card_dict.keys():
if key not in headers:
headers.append(key)
# Append content to content_list for CSV writing
content_list.append(card_dict)
# Write header row
csv_writer.writerow(headers)
# Write contact data
for content in content_list:
row = []
for header in headers:
# Append the value based on header presence
row.append(", ".join(content.get(header, [''])))
csv_writer.writerow(row)
except Exception as e:
print(f"An error occurred: {e}")
def main():
parser = argparse.ArgumentParser(description='Convert VCF to CSV.')
parser.add_argument('-i', '--input', required=True, help='Input VCF file')
parser.add_argument('-o', '--output', required=True, help='Output CSV file')
args = parser.parse_args()
vcf_to_csv(args.input, args.output)
print(f"Successfully converted {args.input} to {args.output}")
if __name__ == "__main__":
main()
