Question about ufw,
I have enabled my fire wall. When I check the status I see that it’s active. But then I see
To Action From
22/tcp ALLOW anywhere
22/tcp (v6)ALLOW anywhere (v6)
Does this mean my port 22 is open and what does (v6) mean? This has me a little worried please help!
Then it’s best that you keep the SSH port closed on your local system, to avoid anyone logging in and taking control of your system. First, you’ll need to check the list of ports that are active. The terminal command to do so is:
sudo ufw status numbered
Glance at the numbered list it will give you and notice which number includes the open port 22. Then execute:
sudo ufw delete number
Replace number with the actual digit of the rule you see for port 22.
That’s it.
Thank You! I was thinking I should get a VPS and was thinking about digital ocean what do you think is a safe and well operating VPS service? I watched the class that Will did on installing a VPS. When I add this should close the port still. I did change the settings to not allow incoming from that port.
Hey Jan,
You’re very welcome!
Digital Ocean is a good one, though I haven’t personally used it. I tried Linode and Kamatera, though the latter has a very peculiar customer support, so I dumped it.
