Trying to Mount My Flash Drive (I think!)
This is with Zorin 16.3 Pro
Hi,
I have a flash drive that I formatted with the disk utility and then I noticed that it does not show up on the linux files utility. So, I tried to implement a mount procedure I saw on-line.
sudo -i
fdisk -l
and among the output:
Disk /dev/sda
(and includes “Disk model sandisk so it definitely “sees” the flash)
Then it said to create a target dir to be used as the USB mount point
mkdir /media/usb-drive
Then it said to execute the mount command to mount to the selected block device name to the created mount dir.
mount /dev/sda /media/usb-drive
Output:
/dev/sda already mounted or mount point busy
At this point I was on my own and don’t know how to continue. The mount point does not show up in the Files utility. I did check in Files for /dev from “Computer” and it shows file “sda” as being a block device (inode/blockdevice).
Anyway, I just want to be able to use the flash drive again.
How should I proceed?
Sometimes it’s the little things, df -h before and then again after inserting will give you your devices mount point clearly, however in this instance, /dev/sda is most likely the primary device you have Linux installed on unless you have performed an advanced installation.
Could you post the output of sudo fdisk -l and then df -h while the disk drive is removed and then again when inserted because you did write that it shows it as /dev/sda
/dev/sdb maybe your target unless of course there is multiple drives/CD/DVD etc.
In addition to MrDeplorableUSA’s excellent comments I’d add that depending on how the drive was formatted you may need to change the ownership so that you can use as a standard user.
I typically run:
Give ownership to the logged in user (you)
sudo chown $USER [the new drive address (/dev/sdb)]
Add the drive to your group
sudo chgrp $USER [the new drive address (/dev/sdb)]
There is probably a better command that removes permissions so anyone can read and write to the drive but I don’t have it handy.
I also use lsblk to triple check the drives connected to the machine. “List the block devices and partitions”
lsblk will show the primary drive tree as /dev/sda with the partitions /dev/sda1…2…x
Hope this helps.
Hey, thanks MrDeplorable for replying! And by the way, I was hoping Files would show the mounted flash drive.
Oh, and I definitely did not do a complicated. Just let Zorin do its thing.
BEFORE
$ sudo fdisk -l
Disk /dev/loop0: 55.68 MiB, 58363904 bytes, 113992 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 55.68 MiB, 58363904 bytes, 113992 sectors
Disk /dev/loop2: 42.73 MiB, 44785664 bytes, 87472 sectors
Disk /dev/loop3: 40.88 MiB, 42840064 bytes, 83672 sectors
Disk /dev/loop4: 40.44 MiB, 42393600 bytes, 82800 sectors
Disk /dev/sda: 238.49 GiB, 256060514304 bytes, 500118192 sectors
Disk model: SanDisk X400 M.2
Disklabel type: dos
Disk identifier: 0xc3edf8fb
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 1050623 1048576 512M b W95 FAT32
/dev/sda2 1052670 500117503 499064834 238G 5 Extended
/dev/sda5 1052672 500117503 499064832 238G 83 Linux
$ sudo df -h
Filesystem Size Used Avail Use% Mounted on
udev 7.6G 0 7.6G 0% /dev
tmpfs 1.6G 1.9M 1.6G 1% /run
/dev/sda5 234G 55G 168G 25% /
tmpfs 7.7G 0 7.7G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 7.7G 0 7.7G 0% /sys/fs/cgroup
/dev/loop0 56M 56M 0 100% /snap/core18/2796
/dev/loop1 56M 56M 0 100% /snap/core18/2812
/dev/loop2 43M 43M 0 100% /snap/freecell-solitaire/2
/dev/loop3 41M 41M 0 100% /snap/snapd/20290
/dev/loop4 41M 41M 0 100% /snap/snapd/20671
/dev/sda1 511M 4.0K 511M 1% /boot/efi
tmpfs 1.6G 132K 1.6G 1% /run/user/1000
AFTER
$ sudo fdisk -l
Disklabel type: dos
Disk /dev/sdb: 29.3 GiB, 31457280000 bytes, 61440000 sectors
Disk model: UDisk
Disklabel type: dos
Disk identifier: 0x107c9477
$ sudo df -h
tmpfs 1.6G 2.0M 1.6G 1% /run
Hey Norseman,
Thanks for replying! Well, I’ll hold off on that and share this. I would have anticipated the sda part of /dev/sda to be a directory. Anyway…
$ ls -l | grep sda
brw-rw---- 1 root disk 8, 0 Jan 25 09:27 sda
brw-rw---- 1 root disk 8, 1 Jan 25 09:27 sda1
brw-rw---- 1 root disk 8, 2 Jan 25 09:27 sda2
brw-rw---- 1 root disk 8, 5 Jan 25 09:27 sda5
$ cd /dev/sda
bash: cd: /dev/sda: Not a directory
But this is all new to me. Then I wonder about MrDeplorable referring to /dev/sda as a real basic pathname and so what is it doing being identified as my flash drive’s mount point?
This is the disk you need to mount:
Disk model: UDisk
Disklabel type: dos
According to this output, /dev/sdb is not mounted, clearly attached just not mounted.
$ sudo df -h
[/quote]
You really need to be extremely careful with your /dev/sda and /dev/sdb since your OS installation is on /dev/sda. Make sure you’re typing the /dev/sdb correctly for your system even if your following a “how to”.
Since you already made the dir earlier all you should need to do is plug it in and mount it:
sudo mount /dev/sdb /media/usb-drive
Then as Norseman pointed out some systems create the drives with root(I believe Ubuntu and Zorin both do this but IDK, I don’t use either one anymore) so you can follow his advice in that post here:
HTH.
Oh man, just an fyi. I had a brainfart. Because my flash drive is a sandisk and /dev/sda says sandisk, I thought it was referencing my flash and not the drive in my computer.
Man!
I am curious, MrDeplorable. What linux distro do you use?
Well, it did not mount. Here is my output.
tony@zorin-1:/media$ sudo mount /dev/sdb /media/usb-drive
mount: /media/usb-drive: wrong fs type, bad option, bad superblock on /dev/sdb, missing codepage or helper program, or other error.
I use straight Debian(still ruining 11) except for wife and kids they use DebianEDU(based off of 11 as well) for their home school stuff and or central tower/server is also a DebianEDU.
As for the error, I’m assuming that the USB thumb drive was previously used with Windows but I would imagine Zorin would have the necessary filesystem type libraries installed to read it mounted a is.
Could you post the out of lsblock as well, with the drive inserted
Here ya go:
$ tony@zorin-1:~/Documents/linux/issues/mounting$ lsblk > ./lsblk_after.txt
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 55.7M 1 loop /snap/core18/2796
loop1 7:1 0 42.7M 1 loop /snap/freecell-solitaire/2
loop2 7:2 0 40.9M 1 loop /snap/snapd/20290
loop3 7:3 0 55.7M 1 loop /snap/core18/2812
loop4 7:4 0 40.4M 1 loop /snap/snapd/20671
sda 8:0 0 238.5G 0 disk
├─sda1 8:1 0 512M 0 part /boot/efi
├─sda2 8:2 0 1K 0 part
└─sda5 8:5 0 238G 0 part /
sdb 8:16 1 29.3G 0 disk
And thanks again!
As to the flash disk, I used the Disks utility to format it. I don’t remember the settings.
