Hi - I am new to Linux. I am using the Ubuntu distro and am having issues downloading the Trezor suit? can anyone help?
Hey @analyst1776 and welcome to the forums!
The AppImage is a self-contained executable file. This means that you’ll need to run it directly from your file manager. One way to do it is to download the Linux app from the website:
https://suite.trezor.io
Then go to your file manager, which defaults to your home
folder and create a folder/directory named AppImages. Once done, go to your Downloads
folder (or where you saved it) and move it to the AppImages folder you created earlier. Once you do that, right-click on it, select properties and on the Permissions tab, select “Allow execution”.
Select OK and then double-click it. If it doesn’t run, then go back to the AppImages folder, right-click on the empty space and select Open in Terminal (or “Open Terminal here”) and type:
ls -l
You will see the name of the AppImage. With the file name I just checked, if you type:
chmod +x ./Trezor-Suite-22.2.3-linux-x86_64.AppImage
Press Enter and then type:
It should work properly. If not, then please let me know of any error message that may have popped on your terminal window.
I hope this works for you!
thanks for the help Vasileious, you are the man! I’ll give it a try when I have some time this weekend.
worked beautifully! Thank you very much!
I am so happy it worked for you! Congratulations on getting it done!
