I have Telegram loaded on Kubuntu and it works okay. However, I do not get notifications of new posts in a timely manner. I have not found a solution in any of the settings tabs. Please help.
Did you get it from their website? I’ve noticed that that one doesn’t work very well. There is a more up to date one available in the snap repository.
Open the terminal and enter the following:
Uninstall your current telegram app:
sudo apt remove --purge telegram-desktop
(You can also delete the file you downloaded from their website)
Then do this:
sudo apt update
Let that finish, and then enter:
sudo apt install snapd
Once that is done, do:
sudo snap install telegram-desktop
Could it be that the channels are muted?
SBHX:
That did the trick! Thank you so much for helping.
IdahoPoes
vasileios:
No, I had all of my channels unmuted. Uninstalling and then reinstalling with snapd did the trick. Thanks for helping me with this issue.
IdahoPoes
To be fair, I was made aware of that fix by @vasileios
That’s why we’re here, my friend! Share knowledge.
And since you covered the SNAP Install aspect, I thought of throwing out another possibility.
