When I created the WP site I am getting an error at the point of setting up the SSL. I am using Namecheap for the VPS and I do have a SSL certificate as part of my Domain. Not sure what to do to finish the setup.Command Line text below.
Successfully created site
Certificate type : domain
Use the flag --force to bypass this check.
You have to set the proper DNS record for your domain
Aborting SSL certificate issuance
I figured it out. Had to go into Advanced DNS setup and add a text line linking the site and IP.
Hello @Circuitriders!
The DNS records can be quite the pain when setting up a VPS. I’ve been battling with them and the SSL and all the 400+ tests that my VPS domain has to go through (which is managed from within the installation, not the VPS provider). Congratulations on solving it!
circuitriders,
Thanks for this post. Could you tell me how you got to the Advanced DNS setup?
I got the same error message.
I use Namecheap and under Manage VPS went to Advanced DNS. Add a record, Type (A Record), Host (@), IP Address. Then did a Refresh of the server. This points the Domain to the IP. Hope this helps.
