Is this what you mean? If not what terminal command should I use to obtain it?
pbkbham@pbk-mini:~$ lspci -v
00:00.0 Host bridge: Intel Corporation Device 4e28
DeviceName: Onboard - Other
Flags: bus master, fast devsel, latency 0
Capabilities: access denied
00:02.0 VGA compatible controller: Intel Corporation JasperLake [UHD Graphics] (rev 01) (prog-if 00 [VGA controller])
DeviceName: Onboard - Video
Flags: bus master, fast devsel, latency 0, IRQ 129
Memory at 6001000000 (64-bit, non-prefetchable) [size=16M]
Memory at 4000000000 (64-bit, prefetchable) [size=256M]
I/O ports at 5000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities:
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Dynamic Tuning service
Flags: fast devsel, IRQ 16
Memory at 6002110000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device_pci_legacy
00:08.0 System peripheral: Intel Corporation Device 4e11
Flags: fast devsel, IRQ 255
Memory at 6002132000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.0 USB controller: Intel Corporation Device 4ded (rev 01) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 124
Memory at 6002100000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Device 4def (rev 01)
Flags: fast devsel
Memory at 6002124000 (64-bit, non-prefetchable) [disabled] [size=8K]
Memory at 6002131000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:15.0 Serial bus controller: Intel Corporation Serial IO I2C Host Controller (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at 4010000000 (64-bit, non-prefetchable) [virtual] [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller: Intel Corporation Serial IO I2C Host Controller (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at 4010001000 (64-bit, non-prefetchable) [virtual] [size=4K]
00:15.2 Serial bus controller: Intel Corporation Device 4dea (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at 4010002000 (64-bit, non-prefetchable) [virtual] [size=4K]
00:15.3 Serial bus controller: Intel Corporation Device 4deb (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at 4010003000 (64-bit, non-prefetchable) [virtual] [size=4K]
00:16.0 Communication controller: Intel Corporation Management Engine Interface (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 127
Memory at 600212c000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Device 4dd3 (rev 01) (prog-if 01 [AHCI 1.0])
DeviceName: Onboard - SATA
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 126
Memory at 7fe00000 (32-bit, non-prefetchable) [size=8K]
Memory at 7fe03000 (32-bit, non-prefetchable) [size=256]
I/O ports at 5090 [size=8]
I/O ports at 5080 [size=4]
I/O ports at 5060 [size=32]
Memory at 7fe02000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:19.0 Serial bus controller: Intel Corporation Device 4dc5 (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at 4010004000 (64-bit, non-prefetchable) [virtual] [size=4K]
00:19.1 Serial bus controller: Intel Corporation Device 4dc6 (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 33
Memory at 4010005000 (64-bit, non-prefetchable) [virtual] [size=4K]
00:1a.0 SD Host controller: Intel Corporation Device 4dc4 (rev 01) (prog-if 01)
Memory at 6002129000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: sdhci-pci
Kernel modules: sdhci_pci
00:1c.0 PCI bridge: Intel Corporation Device 4dbc (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00004000-00004fff [size=4K]
Memory behind bridge: 7fd00000-7fdfffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Kernel driver in use: pcieport
00:1c.5 PCI bridge: Intel Corporation Device 4dbd (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: 7fc00000-7fcfffff [size=1M]
Prefetchable memory behind bridge: 0000006000000000-00000060000fffff [size=1M]
00:1e.0 Communication controller: Intel Corporation Device 4da8 (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 20
Memory at 4010006000 (64-bit, non-prefetchable) [virtual] [size=4K]
00:1e.3 Serial bus controller: Intel Corporation Device 4dab (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 23
Memory at 4010007000 (64-bit, non-prefetchable) [virtual] [size=4K]
00:1f.0 ISA bridge: Intel Corporation Device 4d87 (rev 01)
00:1f.3 Multimedia audio controller: Intel Corporation Device 4dc8 (rev 01)
DeviceName: Onboard - Sound
Flags: bus master, fast devsel, latency 32, IRQ 131
Memory at 6002120000 (64-bit, non-prefetchable) [size=16K]
Memory at 6002000000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: sof-audio-pci-intel-icl
Kernel modules: snd_hda_intel, snd_sof_pci_intel_icl
00:1f.4 SMBus: Intel Corporation JaserLake SMBus (rev 01)
Flags: medium devsel, IRQ 16
Memory at 6002126000 (64-bit, non-prefetchable) [size=256]
I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation JaserLake SPI (flash) Controller (rev 01)
Flags: fast devsel
Memory at 7fe04000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-spi
Kernel modules: spi_intel_pci
01:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b852
Subsystem: Realtek Semiconductor Co., Ltd. Device b852
Flags: bus master, fast devsel, latency 0, IRQ 130
I/O ports at 4000 [size=256]
Memory at 7fd00000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: rtw89_8852be
Kernel modules: rtw_8852be
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
I/O ports at 3000 [size=256]
Memory at 7fc00000 (64-bit, non-prefetchable) [size=4K]
Memory at 6000000000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
