As the title says, I’m having a very “odd” airplane mode behavior on one of 3 Ubuntu 20.04 Laptops.
Quick backstory:
I disabled automatic suspend in favor of blank screen after 15 mins and shutdown after 1 hour(on battery) due to waking up laptops Ubuntu 20.04 would not reconnect to our WiFi only Epson 410 printer without a reboot(or logout and log back in). Each of the 3 laptops are set to no require password when logging in and disabling password prompt on waking up from blank screen as well.
I also found that I had to edit logind.conf and uncomment HandleLidSwitch and set to “ignore” (HandleLidSwitch=ignore).
All was fine till today I noticed while doing updates and installing BeeBEEP LAN Messenger that my youngests HP was “ENTERING” Airplane mode on lid open. I know because I started a new ssh session into her laptop while the lid was closed and did sudo update sudo upgrade etc…
Once I opened her lid to install the BeeBEEP application and set an autostart launcher it kept entering Airplane mode everytime I OPENED the lid, not closing it as I could still start a new ssh session clear up to an hour after closing lid(on battery) and longer while plugged in.
I’m at a loss on this and looking for any suggestions.
Thanks,
Bill
