I am using Zorin Pro but I am used to Linuxmint Mate, they are different to me.
I was wondering what program that will work with it that I can use with my USB drives? I know that member Vasileios uses Zorin and figured that he would know? Any suggestions?
Hey @Keithmj,
Mate uses a different file manager, so that’s the long and short of it. In Nautilus, which is the file manager for Gnome (which Zorin runs on), you can find all your drives in the bottom of the left bar, where they will appear as devices. If they’re not there, then you can click on “Other Locations” and it will present you everything that is connected on your system.
