Error: nvidia-installer must be run as root (OK)
is on screen with a blue line across the middle of screen
when I press ok does it continue or does this cause another problem??
The process did not work in the end. The driver didn’t load because of an error. nvidia installer must be run as root. I have no idea how to do that. When the error came up it prompted me to say ok. I did and it returned back to the ~Downloads$ prompt. Any ideas how to get it to be a root?
Have another error.
ERROR: The installation was canceled due to the availability or presence of an alternate driver installation. Please see /var/log/nvidia-installer.log for more details.
I never attempted to remove the mint driver prior. I verified that the Nvidia driver was not in use and the free and open was still installed. I really don’t know how to do what you suggested. Do we go back into the regular mint or stay here where we are and run this command --remove or --uninstall? Do we need to tell it what to uninstall? --remove /var/log/nvidia-installer.log or some variation of this??
Sounds like a plan, getting late now so I will have a another try in the morning! Thanks for all the help and sticking with me! It will be nice when I can finally get something to load without an error. . .to be continued!!
Well shoot. . . It gave me the same message about canceled installation due to availability or presence of an alternate driver installation, Please see /var/log/nvidia-installer.log for more details. I ran the sudo apt purge nvidia* to no avail. hmmmm…
I don’t know what went wrong but it now says the Nouveau driver is currently in use by your system. This driver is incompatible with the NVIDIA driver, and must be disabled before proceeding.
Soooo the disable part we did originally, is that something that could revert on its own?? do we just go back to mint and toggle it again or is there a way of doing it here?
and I clicked ok and it gave me this message:
For some distributions, Nouveau an be diabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to creat this modproble file for you?
should I say yes or no??
warning: unable to determine the path to install the libglvnd EGL vendor library config files. Check that you have pkg-config and the libglvnd developement libraries installed, or specify a path with --glvnd-egl-config-path.
so I guess i press ok and watch the giant mushroom cloud come out the keyboard? lol
what do i do now??
I hit OK and well son of gun, it finished installing!! I am back in mint!!! So is there anything I need to clean up in the wake of this process? Any house cleaning due to all the excitement of arm wrestling the HP environment etc. . . ??? any tests to perform to make sure all is well?
I have never been here before. . .you know, it worked and now time for next challenge. . . I am usually reinstalling the whole darn thing!
Hey @Paul ! You didn’t hit respond under my post and I wasn’t notified early enough! LOL
For now, there is no catastrophe you will need to face. Worst-case scenario, you can wait until the next version of NVidia production drivers are out and repeat the process. Until then, I believe you are fine!
