I am running #OpenVPN client on #Linux Mint. The connection never restore it self after coming out of sleep. I do however have it set up to run after booting.
Online search offered a solution to check “Specify exit or restarting ping: ping exit 30” in the advanced options of the Network Manger, but it still doesn’t work… I have to turn it on myself.
Would anyone explain the problem and offer a solution? Thank you!
@vasileios, thank you for trying but it’s a no go… I think I will just run it through the OpenVPN3 client from the terminal instead of using the Network Manager and see if that works better.
