[SOLVED] - On my Pixel 3a, I had to go to System > Connected Devices > USB and switch from No file (or was it data?) transfer to File Transfer.
My phone immediately showed up on my Linux machine’s file manager. I started the flash process in the terminal, and everything worked like a charm after that.
I’m trying to install CalyxOS on a Pixel 3a I got from Swappa that is supposedly unlocked.
I’m pretty sure I followed all the directions at Calyxos.org. I’ve tried installing from Linux and from Mac. I’ve tried 3 different USB cable setups. I’ve used version 2.0 of the Flasher (based on a suggestion online).
Each time I get to the point where my laptop doesn’t want to recognize I have a phone connected. I get the error message in the subject line: No devices detected with adb or fastboot.
From what I read, you can connect with one or the other. I don’t understand why, if this is something needed, it’s not addressed anywhere in the directions for installing the OS.
I haven’t tried installing CalyxOS, but I have tried eOS with my Samsung Galaxy S9+. I had to enable fastboot on the phone itself. Is that something that the instructions you’re following had you do?
