On my second go around setting up a VPS with Linode and NameCheap. I can’t ping the nameserver URL - URL will not bring up page. Frustrating!! Any ideas. What info could I give you to help resolve this challenge?
Hey @Dan!
NameCheap has an advanced DNS tab, at the bottom of which there is the Personal nameservers. You can open it and select custom. There you can add the IP address of your VPS under ns1 and ns2. Save the changes and then it should work.
I added this extra detail on the respective PDF on the Server setup on the LMS - if you’re there.
