Oh!, ok yes I am able to pull up the recovery menu but do not see an advanced options section. I sent a image of the menu I see.
The system responded that user âfixerâ does not exist
If the user doesnât exist, it means one of the two following:
- You created a user with a different name
- No user was created.
If itâs the former, then use the usermod command and replace the word fixer with the username you created above.
If you havenât created a user, then youâll need to start from the post above - and the command useradd and take it from there. Just reboot after you execute the usermod command.
Ok, I will play around with it. Thank you so much for helping out. I really appreciate it. Iâll let you know if I am able to get it to work.
Please do! Also let me know if you have any issues along the way.
And youâre very welcome!
