I am having trouble with the LMS website. The Workshop number is advancing properly but it plays old videos. Usually November. I have emailed support and have received no answer. I need help.
I’m new to the LMS and found older dated lessons at the top to begin to listen, learn and advance. Even though the lesson is old the information is still Relevant to learning!
What I also found is the newer class workshops or lessons were at the very bottom. They probably need named better as the reflect the group and a letter specific to the class instead of maybe a full description!
Example: P5 was Python class Group 5.
Then the 001 or 002 is just the sequence of class order!
Hope this is correct and helps, as I’m not support here and I’m new to Jeff
Pro classes.
-Mo
Thanks for your input but it does not help.
