I’ve installed LMDE5 on a MacBook Pro 4,1 three times w/ the same result:
LMDE5 installs completely, then prompts to restart so I can use the new system but won’t let me highlight the Yes choice. It then times out and brings me back to the beginning of the install.
@jspa have you tried using the TAB key? If it is the screen I am thinking of then you can TAB to the correct choice and then hit ENTER. Let me know if that works. Cheers!!
I just installed it again. I was able to sail through the installation putting my name in, password, hitting Next for each screen but when it came to the end, when it asked me to restart, no keys worked. I tried tab, the arrows, return - nothing. Any clue?
Hi BigDaveAZ,
Attached is the photo of the window where I cannot highlight Yes. I have tried tab, return, arrow keys to no avail. Installation reads complete.
p.s. The usb drive is still in the macbook pro. I was under the impression that it would tell me when it was time to remove it.
@jspa congrats. I just had the same experience doing an install of LMDE5, as well. Most distros have a screen that says remove installation media and hit ENTER. Glad you got it solved. Cheers!!
