I have installed and love Linux on my optional computer but need to be able to install my GPS software onto my main computer so I can wipe windows and Bill Gates from my life. I need to be able to run [BaseCamp™ Software](https://www.garmin.com/en-US/software/basecamp/) Mr V. is it possible?
Thanks,
Susie
Hey @vapor!
I was looking at their website and they have it for Windows and macOS.
At this point, I’d say that you have three options:
- Install the WINE compatibility layer and try to run it as a Windows app (you can check the results people have with it here: WineHQ - Basecamp Current)
- Install VirtualBox or VMware Player, install Windows as a Virtual Machine and run BaseCamp there
- Choose one of the free alternatives you can find below:
I am not familiarized with the specific software, but I do use NextCloud that includes a number of GeoTracking (only for you, not shared with any companies) and GeoTagging.
Your help is greatly appreciated. I need this for boating and it’s lobster season soon. Thanks again.
