Re: [Jeff.pro] [Questions] Internet connection problems
Mon, Jun 13 • 22:11
SHOW MORE
Automatic image loading has been blocked to protect your privacy.
Show
More
Hi!
Thank you so much for both of your notes. I really appreciate it. The question I started typing before I was banned again was regarding my internet connection. Ever since I converted my Dell from windows 10 to mint, my connectivity has been mediocre at best…tons of DNS errors. Daily. I actually revisited the post on the forum where you guided someone thru a similar issue who lost their ability to connect after installing proton VPN. I added two new DNS addresses, disabled IPV6 and voilà!
Just checking back. The conversion has rendered my laptop (my primary computer) useless since the conversion. Oddly it wasnt bad a first but slowly lost the ability to connect. Thanks in advance!
Hey @Moana,
Completely losing Internet is troubling. I have noticed that Proton has been having a few issues lately on Mint, having the IPv6leak active even when you disconnect. I have two recommendations for it:
1 - When booting up, check the network
First check to see if the IPV6leak is still running. You can do that via terminal when you execute:
ip link
If you see a connection named “ipv6leak”, you’ll need to delete it via:
sudo ip link delete ipv6leakintrf0
This is something I’ve been doing on my Mint installation quite a bit lately and described the issue here:
Also, on the DNS issue, you can open up your Network Connection in the Settings (for your current connection as in WiFi or ethernet) and put in the following settings (in red):
This will direct your system to resolve DNS via CloudFlare.
If general connectivity becomes an issue, then I’m suspecting it’s the old kernel (your Mint has the 5.4 version, while the latest one is 5.18). In that scenario, you can either upgrade the Kernel or - install the latest Kubuntu distribution, as I show below:
2 - Shift to a newer distro that has a much newer Kernel
In general, Kernels are the motherships that hold all the modules, AKA drivers, for the Operating System. For example, Kubuntu runs on the 5.15 Kernel, which has a huge number of extra hardware supported. It’s environment is also very Windows-like and much more configurable than Cinnamon.
Worst-case, if you enjoy the Cinnamon desktop environment, Linux Mint will update in a week or two with its Mint 21 that will also feature the 5.15 Kernel.
Good morning…thank you so much. I am trying all these solutions today and will report back. I am not married to mint so another distro is an option. My internet does eventually connect. It just takes like 15 mins and then constantly drops.
BTW I unblocked my profile on Tgram. Can you let me know if you can see it now?
Thanks again!
