Does anyone know how to install Linux mint on an iMac as a second operating system? I need the Mac OS for work reasons. So how do I set up mint as an alternate os at boot?
Hey @wwg1wgajoe and welcome to the forums!
What year is your iMac from? The reason I’m asking is that since 2018, Apple introduced the T-2 chip, which will make the process a bit different.
You could boot into the macOS, select the apple icon on the top left and select “About this Mac” and please attach the window info so that I get a good idea of the specs. Thank you!
It’s a 2013 iMac
16GB RAM combo flash HDD drive at 1 TB
Thanks
JT
Anytime @wwg1wgajoe!
The following article has a very good, step-by-step process as to how you can dual-boot your system. It’s for an older version of Ubuntu, but since your iMac is a 2013 version, it will work as well.
https://www.maketecheasier.com/install-dual-boot-ubuntu-mac/
I assume this works for Linux mint also?
Linux Mint is Ubuntu derrived, so it’s the same architecture.
