I’ve downloaded the driver and it is sitting in downloads. I have the instructions from brother to install Linux .deb 64 bit for Ubuntu. Here they are:
Download the driver.
Login as a superuser (or use “sudo” option if required) .
Install the driver.
Turn on your MFC/DCP and connect the USB cable.
Open the terminal and go to the directory where the driver is.
Install the scanner driver.
4.Command (for dpkg) : dpkg -i --force-all (scanner-drivername)* -
Check if the driver is installed.
5.Command (for dpkg) : dpkg -l | grep Brother*
In trying to work in terminal, this is what I’m getting:
kim@kim-Inspiron-5570:~$ cd Downloads
kim@kim-Inspiron-5570:~/Downloads$ dpkg -i --force-all
dpkg: error: required read/write access to the dpkg database directory /var/lib/dpkg
kim@kim-Inspiron-5570:~/Downloads$ dpkg -i --force-all br-5
kim@kim-Inspiron-5570:~/Downloads$ dpkg -l | grep Brother
ii brscan5 1.2.9-0 amd64 Brother Scanner Driver brscan5
ii printer-driver-brlaser 6-1build1 amd64 printer driver for (some) Brother laser printers
ii printer-driver-ptouch 1.4.2-3 amd64 printer driver Brother P-touch label printers
kim@kim-Inspiron-5570:~/Downloads$ update all
kim@kim-Inspiron-5570:~/Downloads$ sudo dpkg -i --force-all brscan5-1.2.9-0
[sudo] password for kim:
dpkg: error: cannot access archive ‘brscan5-1.2.9-0’: No such file or directory
kim@kim-Inspiron-5570:~/Downloads$ dpkg -i --force-all brscan5-1.2.9-0.amd64.deb
kim@kim-Inspiron-5570:~/Downloads$ sudo dpkg -i --force-all brscan5-1.2.9-0.amd
dpkg: error: cannot access archive ‘brscan5-1.2.9-0.amd’: No such file or directory
I’ve tried every iteration I can think of to install the file. I cannot open the .deb file in terminal. Everything is extracted. The GDebi Package Installer tells me the scanner is already installed, but I can’t find it.
Any ideas? Thanks.
