I have an SSD from a laptop that suddenly went read-only. It is encrypted and the operating system is Pop OS. Laptop won’t boot.
I would like to see if I can get this drive mounted on another machine. Also running Pop OS, and also with its own encrypted drive.
When I plug in the drive it prompts for a password, but the drive isn’t mounted – more specifically, the cryptdata partition won’t mount.
Don’t know much about LUKS. Tried these commands:
sudo cryptsetup luksOpen /dev/sdb3 cryptdata
sudo lvscan
sudo vgchange -ay
The first command results in “Device cryptdata already exists”. I think this is because the machine I’m trying this on has an encrypted drive as well. If I use a name other name cryptdata, I get a message “cannot use device /dev/sdb3 which is in use (already mapped or mounted)”. From the Disks app, /dev/sdb3 shows that it is already unlocked – I assume because it prompts for a password when plugging in the drive.
The lvscan issues a warning about duplicate VG names, showing one inactive and one active /dev/data/root. Also /dev/mapper/data-root already exists (using df command).
In /dev/mapper there is is cryptdata, data-root, and a luks (plus UID). I’m thinking the luks-* device is the unlocked /dev/sdb3 – but I’m not sure how to address the lvscan/duplicate VG names.
lsblk looks like this:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931.5G 0 disk
└─sda1 8:1 0 931.5G 0 part
sdb 8:16 0 931.5G 0 disk
├─sdb1 8:17 0 512M 0 part
├─sdb2 8:18 0 4G 0 part
├─sdb3 8:19 0 923G 0 part
│ └─luks-d6e5251e-7a53-4446-ab24-1b267da3bf42
│ 253:2 0 923G 0 crypt
└─sdb4 8:20 0 4G 0 part
nvme0n1 259:0 0 931.5G 0 disk
├─nvme0n1p1 259:1 0 487M 0 part /boot/efi
├─nvme0n1p2 259:2 0 3.8G 0 part /recovery
└─nvme0n1p3 259:3 0 927.2G 0 part
└─cryptdata 253:0 0 927.2G 0 crypt
└─data-root 253:1 0 927.2G 0 lvm /
I’ve since tried a bunch of stuff that I can’t remember. Whenever the drive does appear in Nautilus, I click on it and after a few seconds, get a dialog box that says "operation cancelled.
It may be that the drive is just busted. But if anyone has some suggestions, I would like to see if I can get it mounted, even if read only.
