Hi, I only see Favorites, Recents and Contacts.
I checked the app permissions and I only denied Location. It has everything else. I tried loading the Simple Dialer but that one does the same thing.
I transitioned from an iPhone on Verizon.
Not sure if either of those comes into play.
Last minute edit
Just checked the settings and finally found Visual Voicemail and turned it on.
Hopefully, this will work out.
Thanks for the quick reply which just prompted me to dig a bit more.
