Firewall for Ubuntu 20.04 ufw not found
I installed ubuntu 20.04 on a HP COMPAQ 15 SG19n . I could not find ufw not with applications, there is also no icon for it on the display. So I installed it from the store, but still when I search for it “no results”. When I try to install with terminal “sudo apt install ufw” it comes back with “ufw is already the newest version (0.36-6ubuntu1).” Now I am stuck - can anybody help?? thank you!
To start: sudo ufw enable
To end: sudo ufw disable
For status: sudo ufw status
Here is a site… Not sure if significant difference for ufw between Ubuntu 20.04 and 18.04.
Here is a site for Ubuntu 20.04 ufw:
https://www.arubacloud.com/tutorial/how-to-set-up-and-configure-ufw-firewall-on-ubuntu-20-04.aspx
Thanks a lot, I was looking for some GUI application I had seen on a website but as I couldn’t find anything did it in the terminal. And now I got reassuránce from you. that’s always great to get support in struggling. Next step is printing with strange errors when setting up hplip…
There is a GUI version called gufw. To install use:
sudo apt install gufw
In the list of applications, it is called Firewall Configuration.
