Dear Sirs,
I was trying to install wordpress on a VPS using WordOps. WordOps installed successfully.
The next command I used was “sudo wo stack install”
It worked until it got to Downloading NetData and instead of printing [Done], it showed…
root@198-74-55-193:~# sudo wo stack install
WP-CLI is already installed
Start : wo-kernel [OK]
Adding repository for MySQL, please wait…
Adding repository for NGINX, please wait…
Adding repository for PHP, please wait…
Adding repository for Nano, please wait…
Updating apt-cache [OK]
Installing APT packages [OK]
Applying Nginx configuration templates
Testing Nginx configuration [OK]
Restarting Nginx [OK]
Configuring php7.3-fpm
Restarting php7.3-fpm [OK]
Tuning MySQL configuration [OK]
Restarting mysql [OK]
Restarting fail2ban [OK]
Configuring Fail2Ban
Configuring Sendmail [OK]
Downloading PHPMyAdmin [Done]
Downloading phpRedisAdmin [Done]
Downloading Composer [Done]
Downloading Adminer [Done]
Downloading Adminer theme [Done]
Downloading MySQLTuner [Done]
Downloading Netdata Traceback (most recent call last):
File “/opt/wo/lib/python3.7/site-packages/urllib3/connection.py”, line 175, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File “/opt/wo/lib/python3.7/site-packages/urllib3/util/connection.py”, line 73, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File “/usr/lib/python3.7/socket.py”, line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
File “/opt/wo/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 706, in urlopen
chunked=chunked,
File “/opt/wo/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 382, in _make_request
self._validate_conn(conn)
File “/opt/wo/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 1010, in _validate_conn
conn.connect()
File “/opt/wo/lib/python3.7/site-packages/urllib3/connection.py”, line 358, in connect
conn = self._new_conn()
File “/opt/wo/lib/python3.7/site-packages/urllib3/connection.py”, line 187, in _new_conn
self, “Failed to establish a new connection: %s” % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7ff3ce98c320>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File “/opt/wo/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/opt/wo/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 756, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File “/opt/wo/lib/python3.7/site-packages/urllib3/util/retry.py”, line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘my-netdata.io’, port=443): Max retries exceeded with url: /kickstart-static64.sh (Caused by NewConnectionError(’<urllib3.connection.HTTPSConnection object at 0x7ff3ce98c320>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’))
File “/opt/wo/lib/python3.7/site-packages/wo/core/download.py”, line 26, in download
req = requests.get(url, timeout=(5, 30))
File “/opt/wo/lib/python3.7/site-packages/requests/api.py”, line 75, in get
return request(‘get’, url, params=params, **kwargs)
File “/opt/wo/lib/python3.7/site-packages/requests/api.py”, line 61, in request
return session.request(method=method, url=url, **kwargs)
File “/opt/wo/lib/python3.7/site-packages/requests/sessions.py”, line 542, in request
resp = self.send(prep, **send_kwargs)
File “/opt/wo/lib/python3.7/site-packages/requests/sessions.py”, line 655, in send
r = adapter.send(request, **kwargs)
File “/opt/wo/lib/python3.7/site-packages/requests/adapters.py”, line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘my-netdata.io’, port=443): Max retries exceeded with url: /kickstart-static64.sh (Caused by NewConnectionError(’<urllib3.connection.HTTPSConnection object at 0x7ff3ce98c320>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’))
File “/usr/local/bin/wo”, line 8, in
sys.exit(main())
It continued with these Traceback notifiactions.
Using Linode on Debian, client is Ubuntu 20.04
Thanks in advance for any assistance.
-Tony
