I must say (being old enough 2 be a Pappy) this should be copied and pasted to NVidia’s R&D team…the fact that even granny’s (& pappy’s) know…they got issues
says it ALLLLLLLLLLLLLL
come on Nvidia…get with the GAME!!
Just connected the HP directly to the 24" Dell monitor using an HDMI to HDMI cable and VIOLA, I am mirroring the screen. The Dell 7202 has a mini HDMI port that will likely provide the same results going directly to the 24" Dell monitor. My issue is that i will still be unable to access the DisplayLink port to run other accessories. I’ll contact Dell and see if they have a mini HDMI to the DisplayLink cable, not sure what that end is?
quote=“Chewit229, post:22, topic:2437, full:true”]
Here you go. I do appreciate all of your efforts
pj@pj-Latitude-12-Rugged-Tablet-7202:~$ inxi -Fzx
System:
Kernel: 5.4.0-104-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 5.2.7 Distro: Linux Mint 20.3 Una
base: Ubuntu 20.04 focal
Machine:
Type: Portable System: Dell product: Latitude 12 Rugged Tablet 7202 v: N/A
serial:
Mobo: Dell model: 00M0JT v: A01 serial: UEFI: Dell v: A19
date: 01/23/2018
Battery:
ID-1: BAT0 charge: 18.3 Wh condition: 18.3/26.0 Wh (70%)
model: SMP DELL FH8RW4CT status: Full
ID-2: BAT1 charge: 20.7 Wh condition: 20.7/26.0 Wh (80%)
Device-1: hidpp_battery_0
model: Logitech Marathon Mouse/Performance Plus M705
charge: 55% (should be ignored) status: Discharging
Device-2: hidpp_battery_1 model: Logitech MK700
charge: 70% (should be ignored) status: Discharging
CPU:
Topology: Dual Core model: Intel Core M-5Y71 bits: 64 type: MT MCP
arch: Broadwell rev: 4 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 11174
Speed: 799 MHz min/max: 500/2900 MHz Core speeds (MHz): 1: 798 2: 799
3: 798 4: 798
Graphics:
Device-1: Intel HD Graphics 5300 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0
Display: x11 server: X.Org 1.20.13 driver: modesetting
unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 5300 (BDW GT2) v: 4.6 Mesa 21.2.6
direct render: Yes
Audio:
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:03.0
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.4.0-104-generic
Network:
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: f040
bus ID: 01:00.0
IF: wlp1s0 state: up mac:
IF-ID-1: wwan0 state: down mac:
Drives:
Local Storage: total: 238.47 GiB used: 46.34 GiB (19.4%)
ID-1: /dev/sda vendor: LITE-ON model: CV3-8D256-11 SATA 256GB
Partition:
ID-1: / size: 233.24 GiB used: 46.34 GiB (19.9%) fs: ext4 dev: /dev/sda2
Sensors:
System Temperatures: cpu: 41.0 C mobo: 32.0 C sodimm: 32.0 C
Fan Speeds (RPM): cpu: 3905
Info:
Processes: 209 Uptime: 7m Memory: 7.34 GiB used: 1.48 GiB (20.2%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
[/quote]
Thank you. I’ll see what the Dell website has on a cable
Is the Ubuntu 20.4 release similar to the Mint 20.4 release? If so, will the instructions in the below link be helpful to me?
Thank you,
Updated the Dell Ubuntu Driver and ran update and upgrade commands after reading some sage advice you posted on Jeff.Pro. I see some minor changes although I have no idea how they affect your interpretation of the output. Thank you again for your patience.
System:
Kernel: 5.4.0-105-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Machine:
serial:
date: 01/23/2018
Battery:
ID-2: BAT1 charge: 20.5 Wh condition: 20.7/26.0 Wh (80%)
model: SMP DELL FH8RW4CT status: Charging
CPU:
bogomips: 11174
Speed: 798 MHz min/max: 500/2900 MHz Core speeds (MHz): 1: 798 2: 799
3: 798 4: 798
Graphics:
bus ID: 00:02.0
direct render: Yes
Audio:
Device-3: DisplayLink USB3.0 Hub type: USB driver: cdc_ncm,snd-usb-audio
bus ID: 3-2.2:3
Sound Server: ALSA v: k5.4.0-105-generic
Network:
bus ID: 01:00.0
IF-ID-1: enx9cebe8463d74 state: down mac:
IF-ID-2: wwan0 state: down mac:
Drives:
Local Storage: total: 238.47 GiB used: 49.67 GiB (20.8%)
Partition:
ID-1: / size: 233.24 GiB used: 49.67 GiB (21.3%) fs: ext4 dev: /dev/sda2
Sensors:
System Temperatures: cpu: 53.0 C mobo: 45.0 C sodimm: 47.0 C
Fan Speeds (RPM): cpu: 4360
Info:
Processes: 234 Uptime: 1m Memory: 7.34 GiB used: 1.20 GiB (16.3%)
inxi: 3.0.38
It’s pretty hard to compare on the phone, one thing did jump out in the 2nd output was of “Device 3…” USB display… After you had followed that links advice. Could will be it’s not your doing but what you’re fighting against. A good old fashioned bug.
You could probably get a mini-HDMI to HDMI at any local electronics stupid for half the cost of Dell/ +s/h.
Thank you. After some more research it appears that the DisplayLink folks are trying to correct a display bug in Ubuntu, which I assume is present in Mint?
I’ll go ahead and get a mini HDMI to HDMI cable for the interim.
I greatly appreciate your help
Hello,
It’s been a crazy few weeks… Finally received the mini HDMI to HDMI cable and Viola!, I can now mirror to the 24 Dell monitor. The display Link has three USB ports which are all working, including a wireless mouse and keyboard.
It appears that the Display Link folks have a bug and they are working on it with no known scheduled release date. They have a work around for Ubuntu 20.4, but nothing discussed for Mint.
For now I’m back to normal with a few extra wires here and there. I sincerely appreciate all of your help MrDeplorableUSA. You have kept me in the game in this new, to me, Linux environment. Can’t wait to learn more about Linux and convert the rest of my extended family. Again, thank you!
