Hello,
I’ve run into an issue with a fresh install of Debian Bookworm to a new nvme m.2 ssd.
After 5-6 attempts to install Debian, the post install fails to boot. No grub errors.
I’ve tried re-installing Grub from LIVE DVD several different ways to no avail.
In the Bios set-up I’ve manually tried to set-up the new NVME but it after booting it resets the drive info from PCI(…) to VenHW(…) [VenHW appears to be a windows boot manager setting]
I now believe the BIOS/EFI is full or corrupted. There are 16 boot listings showing in efibootmgr.
Suspect #1
Initially the no-graphical expert install completed with a question to update NVRAM which I’d not seen before and accepted with YES.
Norse
