I have installed Virtualbox on my Mint OS, then installed Windows 10, all works great. I want to install software using a USB but Virtualbox is not picking it up. I did some resurch and installed the extention pack for Virtualbox but still not picking it up to add. Any suggestions?
I haven’t used VB in a while but I believe you need to shutdown the VM. edit the settings for the WIN10 VM and enable USB. Again, it’s been quite some time since I used VB.
Someone still using it might offer better guidance or the VB forums.
