When i click on it, it gives me the following notification: “efi partition system not usable”.. “Your EFI System Partition (ESP) is not mounted at /boot/efi. Please ensure it is properly configured and try again”. (see pic.
press “yes” … upgrading would succeed but i’ve noticed that after rebooting and doing " uname -a " i am still on older kernel 5.15.0.57 instead of 5.15.0.58
if i click “no” instead of “yes” i would then be sent back to screenshot 1..
Now after rebooting uname -a still 5.15.0.57 tried a sudo apt update result was 19 packages can be upgraded … did sudo apt upgrade …installed but when typing again sudo apt update i still get the same list of pkgs..
Seems that they may have unmet dependencies or something:
Read here for similar: Packages held back
Cautious solution 1:
Per Pablo’s answer, you can run sudo apt-get --with-new-pkgs upgrade, and it will install the kept-back packages.
This has the benefit of not marking the kept-back packages as “manually installed,” which could force more user intervention down the line (see comments).
If Pablo’s solution works for you, please upvote it. If not, please comment what went wrong.
Cautious solution 2:
The cautious solution is to run sudo apt-get install <list of packages kept back>. In most cases this will give the kept-back packages what they need to successfully upgrade.
Thank you so much MrDeplorableUSA for your help.
Couldn’t fix the issue so I finally re-installed Ubuntu from scratch … i probably did some wrong last time when partitioning during install…this time i left ubuntu installer do the job instead. Now ev’thing works fine…
Sorry you had to do that.
Hopefully you didn’t loose much.
I try to avoid gpt/uefi but one day I’m sure I’ll have to deal with it. I’m also not much of an Ubuntu fan anymore due to snaps, its a good starter distro for newcomers but so is Mint(also Debian/Ubuntu based) but no forced snaps.
oh no worries, ive just installed 2 weeks ago, i did not loose anything, actually im on a fresh install and it finally works fine…i unfortunately need using 2 apps that only exist as snap version …
again MrDeplorableUSA, a big thank you!
im using Authy & Tradingview but im now testing another 2fa app called Authentificator* (its a flatpak (but at least it does not asks a phone number like Authy)…pb is i was getting an error restoring the backup file (a text file). Since i’ve re-install Ub 20.04.5 and deleted my second disk (w/22.04) i now have efi correctly located @ /boot/efi and i dont get this issue anymore when restoring Authentificator’s data …
*actually i got introduced to Authentificator thru Jeff’s TG channel…
