Best linux System for Audio
I need help !! I have a 20 year old Audio Mix engine that was written for XP and now has issues with Windows 11… I know Linux is the right move. Need help finding the right path.
Can i run an XP app in linux… I tried running sn emulator and had issues with the drivers
Any help is appreciated
If you have installation media for XP, you MIGHT be able to create an XP virtual machine. Whether or not a virtual machine would meet your needs is another question.
What’s the usage or the XP app, as in what do you use it for? There very well may be a similar application for Linux.
What is the make of your mix engine? What Distro are you using?
@RobertDurkee11 , this was just posted in Bones Tech Garage on Telegram (5 Linux Distos Built for Creative Work):
There may be something here that helps.
Good stuff right here. Being that I focus more on the O/S and utility, the creative side of computing isn’t really in my sphere.
