My phone exported contacts as VCF, but my CRM only accepts CSV. How do I convert without losing fields?
I can’t take credit of for this, I just did some modification to it. Here’s some python code to convert from VCF to CSV.
./vcf-to-csv.py -i filename.vcf -o filename.csv
#!/usr/bin/env python3
#  may need to run "pip install vobject" first
import csv
import vobject
import argparse
def vcf_to_csv(vcf_file, csv_file):
    try:
        with open(vcf_file, 'r', encoding='utf-8') as vcf:
            # Read all VCards
            vCards = list(vobject.readComponents(vcf.read()))
            print(f"Total vCards read: {len(vCards)}")
            if not vCards:
                print("No vCards found.")
                return
            with open(csv_file, 'w', newline='', encoding='utf-8') as csvfile:
                csv_writer = csv.writer(csvfile)
                # Empty lists to hold headers and content
                headers = []
                content_list = []
                # Extract headers and content
                for card in vCards:
                    # Temporary dictionary for the current card
                    card_dict = {}
                    for key, value in card.contents.items():
                        # Capture all keys and their values
                        if isinstance(value, list):
                            card_dict[key] = [str(v) for v in value]  # Convert value(s) to string
                        else:
                            card_dict[key] = str(value)
                    # Only add keys to headers if they don't already exist
                    for key in card_dict.keys():
                        if key not in headers:
                            headers.append(key)
                    # Append content to content_list for CSV writing
                    content_list.append(card_dict)
                # Write header row
                csv_writer.writerow(headers)
                # Write contact data
                for content in content_list:
                    row = []
                    for header in headers:
                        # Append the value based on header presence
                        row.append(", ".join(content.get(header, [''])))
                    csv_writer.writerow(row)
    except Exception as e:
        print(f"An error occurred: {e}")
def main():
    parser = argparse.ArgumentParser(description='Convert VCF to CSV.')
    parser.add_argument('-i', '--input', required=True, help='Input VCF file')
    parser.add_argument('-o', '--output', required=True, help='Output CSV file')
    args = parser.parse_args()
    vcf_to_csv(args.input, args.output)
    print(f"Successfully converted {args.input} to {args.output}")
if __name__ == "__main__":
    main()
