That was my first choice. As luck would have it LG ended their unlocking program just hours before I tried to unlock mine. So it went back and I ended up with a Pixel 4xl. If your bootloader is unlocked be sure you have everything you need before starting. Good luck!
You can also check in with Boneās Tech Garage on Telegram for tips and ideas and help when flashing a phone
I was recently given a Pix 3 and am going to use it for a while before making a decision about the LG. After years with the iPhone, this is a big adjustment. I am committed to the switch, but it isnāt easy. I didnāt realize how much I had come to depend on the deviceā¦
Thanks, Hannah girl!
Pixels are an easy switch to Graphene. There is a web installer.
