I ran the Disks format process, @vasileios. Disks sees the SD card; Files does not. I have installed GParted if the problem is no boot sector. But I’ll need guidance on how to use it, sizes, format-types, etc. Total newbie, here!
Thank you for sending the images! From the image below, click on the designated icon, while you have your SD Card highlighted and select Format & send me a screenshot of the window that pops up.
It will work with those options, yes. Though, if you want to be truly Linux only, then I’ll need to know its device name, which lies under the big green bar. In that scenario, you can hit the terminal and give it the exact filesystem you like.
But still, the DOS (figure of speech, DOS), will work.
Here’s the result of my 2nd SD card format attempt, using Disks, @vasileios. Nothing changed. Files still doesn’t see it, and it doesn’t mount to my desktop.
@vasileios, via Terminal, I found the device, but don’t know how to rename it. Here’s my attempt, with Bash’s response (Looks as if the filenames need extensions?):
You cannot rename the device itself, only to assign a Label to it. This can be done in Gnome Disks you ran earlier - when you hit on the gear under the big bar to the right and select the FileSystem option (I’m on a different system and I don’t have Disks available now… first time in a while - go figure!).
@vasileios, you are amazing! In the process of setting up TimeShift, I came to the Home Directory option, no where else suggested why one should include Home, I should’ve searched for answers here first!
But I suppose I don’t need to include Home for root?
Hey @Ai!
Root home is only required in case you run a distro like Kali, where the system logs you in as root to begin with - and the entire home directory structure is populated.
As for your own Home folder, make sure you have enough space on your target area, as the backup GB can accummulate.
Unless the drive you’re backing up to is BTRFS formatted, which makes it more economic.
Another option that has saved me several times is Clonezilla. I love this app! once I have everything set up, installed and tweeked I clone the machine. If / when I do something that I cant fix Clonezilla is my go to. I highly recommend it.
That is great to hear! Thank you so much for the info @waynetb!
Lately I’ve been “playing” around with OpenSUSE Tumbleweed, which I’ve installed on a Surface Laptop 3 and a MacBook Air (where I’m writing from). It’s definitely more challenging than most distros, but the lessons I learned apply to all flavors out there.
At some point, I’ll have to prepare a unified cloud solution - as I find myself working on many, different devices.
